It is currently Tue Aug 12, 2025 12:49 pm
PostPosted: Wed Dec 09, 2015 12:29 pm
I'm thinking to make a multi-radi horizontal sliding thing for the sander with changeable "holsters" with vacuum for each size block. Am I over thinking this? It doesn't take too long to do freehand, but ya-know....
These users thanked the author Pmaj7 for the post: DannyV (Thu Dec 10, 2015 2:52 am)
PostPosted: Wed Dec 09, 2015 2:02 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I've seen a couple nice designs of jigs for that task. I think a couple of them can be found on this forum. I've not bothered though because freehanding it on the belt sander is so fast and works fine.
PostPosted: Wed Dec 09, 2015 2:04 pm
Yes we have both -- fashioned the contours with Bondo attached adhesive backed abrasive, very simple works great. We actually make our J185 and J200 tail blocks on our CNC machines --- stacked laminated glue ups.
Ken Cierp
These users thanked the author kencierp for the post: DannyV (Thu Dec 10, 2015 2:52 am)
PostPosted: Wed Dec 09, 2015 2:19 pm
Mine's a bit clumsy but works- T shaped board clamped to the linisher (belt sander) table, swinging arm with a bolt locating various radius points.
Vertical plate on the end off the swinging arm gets required block screwed to it.
Start linisher, swing arm with block.
But sometimes I just mark the radius from the mold on it, use a block plane and finesse it in the mold with abrasive, less hassle than setting it up if it's just one at a time.
PostPosted: Wed Dec 09, 2015 2:42 pm
Ken, are you talking about a sanding block like a fret board sanding block?
Screws?! But that would be so much easier than rigging up a vacuum setup! err...why didn't i think of that?!
I just found this where TK uses a pattern sander setup. Hmm....less space! viewtopic.php?f=10101&p=274515#p274515
PostPosted: Wed Dec 09, 2015 3:58 pm
Timely thread. I just revised mine so I can radius a headblock with the fretboard suport attached. I also put a spline down the center to keep the two pieces aligned.
Clamping setup works but is not elegant. Vacuum would be ideal.
The jig seems to work fine as did it's predecessor.
These users thanked the author Terence Kennedy for the post (total 2): DannyV (Thu Dec 10, 2015 2:52 am) • Pmaj7 (Wed Dec 09, 2015 4:55 pm)
PostPosted: Wed Dec 09, 2015 4:37 pm
Yep -- upside down with rails, not in the shop now but I can take and post a picture if you'd like
Ken Cierp
These users thanked the author kencierp for the post: Pmaj7 (Wed Dec 09, 2015 4:55 pm)
PostPosted: Thu Dec 10, 2015 2:17 am
Nice upgrade!
I am leaning toward the pattern fence on the sander because it's smaller. Plus I'm sure I could come up with a few other ways to use that. Just have to make a new bottom plate for every radius.
PostPosted: Thu Dec 10, 2015 10:45 am
Here's our Martin block contouring station (tail and neck) -- pretty simple. I use Bondo to form the contours. I count strokes and change the edge in an effort to keep them symmetrical -- about a minute or so. I make the more rounded tail block on the CNC machines.
Ken Cierp
These users thanked the author kencierp for the post: Pmaj7 (Thu Dec 10, 2015 9:13 pm)
PostPosted: Thu Dec 10, 2015 11:18 am
Just curious -- how did the expression "head block" become synonymous with "neck block" and "heel block" the latter two in my view being self explanatory?
Ken Cierp
PostPosted: Thu Dec 10, 2015 11:27 am
First name: Jay
City: Bothell
State: Washington
As opposed to tail block, I suppose.
PostPosted: Thu Dec 10, 2015 11:44 am
That makes sense --- but again, the term I learned was "end block"
Ken Cierp
PostPosted: Thu Dec 10, 2015 1:27 pm
I make up my own terms sometimes!
PostPosted: Sat Dec 12, 2015 3:06 pm
First name: Jay
City: Bothell
State: Washington
You got me wondering about this because the origins of terms interest me. It turns out I got tail block from Sloane's book on classical guitar construction and head block from Cumpiano's book, which also uses the term tail block.
PostPosted: Sat Dec 12, 2015 4:02 pm
Last Name: Beaver
City: Lake Forest
Ok, I can see radiusing an end block, which I free hand on a belt sander. I can see where the jig would be a step up, But I always thought a neck block should be flat were the neck meets the sides. Am I wrong? (again)
Joe Beaver
Maker of Sawdust
PostPosted: Sat Dec 12, 2015 4:22 pm
First name: Jay
City: Bothell
State: Washington
The neck block doesn't have to be flat in the neck/body joint. It depends on the design of the body shape. The curvature of the upper bout sides can be continued through the neck joint, although that's certainly not the case for most guitars.
PostPosted: Sat Dec 12, 2015 8:38 pm
My SJ has a radiused neck & tail block, I was reminded of this today as I free-handed them on the drum sander. I have built jigs for everything else, probably time to make one for this operation as well.
Gwaltney Guitars
Users browsing this forum: Bing [Bot] and 27 guests
